Rear side skirt clips
Whilst on this thread Vinny if you dont mind The below question may or may not help the post but......
Can somebody please tell me which ones are which i know im some items missing but not sure what i quite need to order, my car seems to have an assortment....and before anybody says anything they havent been cleaned up yet
Thanks
Mart
Thanks
Mart
Thanks
Mart
Thanks
Mart
The ones on the far left go under the carto fasten the skirt to the underside
The Six on the right push into the sill with the clip facing upwards.
The ones in the middle attach to the side skirt itself.
The tricky bit is lining all the clips up, and being gentle when reattaching - As I broke some replacing mine abit ago
I forget how many go on each side, but the fronts are slighty different to the rear ones
cheers for that
I knew the ones down the left,i need 2 more of them if the others clean up ok, its the others that i need to know i cannot remember what was where when i took them off as some were missing anyway, previous owner half hearted fix
Thank you
Thank you
Originally Posted by THE RADMAN
martin, that bunch of 9 must be from a diff model as they arent orig cossie ones, did they fit ok? as it would be worth knowing what theyre from
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
