escos engine mounts
Old Oct 21, 2007 | 11:39 AM
dake205's Avatar
dake205
Default escos engine mounts
whats the best way to remove them and does the subframe have to be dropped
Old Oct 21, 2007 | 11:59 AM
Kelv's Avatar
Kelv
Almost there!
when i first changed mine i dropped the crossmember very slightly, just let it drop a little but still left the long bolts in that hold it to the chassis.
i also had the engine lifted slightly which gave enough space to access it all properly.
in fairness i then cut the old mounts out as they were fooked anyway, and the new vibra technics mounts that then went in wernt as tall as the standard ones, so they slipped into place relatively easily!
if that helps
Old Oct 21, 2007 | 01:56 PM
S3an's Avatar
S3an
as said just cut them out and take the new ones to pieces to to install them. i found that threads on the new vibratech ones were shorter and the top nuts just and no more covered the threads.
Old Oct 22, 2007 | 08:27 AM
Mr.Ford's Avatar
Mr.Ford
if that helps
Does your Escort have aircon???
Mine does, and when I look to the space....it's horrible to get access to the engine mount (header tank side)
Any options?
Old Oct 22, 2007 | 08:55 AM
Kelv's Avatar
Kelv
Almost there!
Air con, thats something that should find its way into the dustbin
SmudgerByName
52
Jul 28, 2016 06:14 PM
james kiely
Aug 28, 2015 08:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
