Turbo spool up time
Turbo spool up time
Hi all, I've got a big turbo cosworth engine in my car running stage 1, its a standard turbo but i have just fitted an electronic boost controller and the difference is really noticable. Before i was hittin 14psi at around 5000rpm now it hits it at 3500rpm. i was just wondering what kinda revs everyone hits full boost at? Are there any easy ways to reduce the time it takes to spool up, i like having it rev freely all the way to 7000rpm so i dont really want to downsize my turbo. Any help would be much appreciated. Cheers
Alex
Alex
Almost there!
my old setup being on a UT T38 and greys used to be able to give me full boost of about 36psi by 3400rpm.
i was shocked at how savagely the boost came in.
for me this was an awesome setup for a road car - im just hoping the new engine and spec (if i dont break the car over the coming weeks) will be alot better
Alex
Alex
Alex
My escort was running a T34.48, and with msd's mapping it was on 25psi well under 3000RPM
Did you ever get it dyno'd or rolling roaded?
Almost there!
Wil, i never had it on a rolling road to prove its power
it was all taken care of by Steve Scott, and yes it was so much stronger than my T34 ever gave me all the way thru the rev range, you could actually feel were the T34 used to give up slightly.
the T38 just felt like it got stronger as the revs increased
2.5 bar at 4k on my T4
- Thats great figures for a T4, where does it start making boost? My T4 saff is a mare' to drive, but have not really had a chance to give it a proper shakedown and set-up yet
Almost there!
Originally Posted by RWD_cossie_wil
It sounds like your car had a fault before you fitted the boost controller, a T34.48 should be on full boost by 3500RPM easily....could depend on who's chip the car is running as well?
Alex
Almost there!
Is there anything else that could be making it take so long to spin up? Thanks
Alex
Alex
Yeah spins up to around 14psi depending on outside temp and holds it lovely, it did this without the boost controller before, it just does it a lot faster now. Just not as fast as everyone else it seems!
Alex
Alex
I hade this problem on my escort. Didn`t find any air-leak, but changed the plenum gasket anyway. When I removed the plenum I saw half of the gasket was missing.
Now everything is
Now everything is
got 2.3 bar at 3500rpm on new turbo as of set up today
Shit the bed
Just loads to do, finish the engine build, fit the hydrualic clutch, and loads of bits like poly bushes, coil-overs, big brakes etc etc etc.... The main hassle is I need bits to finish the engine build but still waiting for them
I am hoping it will be running and ready to run-in by friday latest ... Didn't realise you lived so close mate, saw your car parked on the drive today, looked
Matt Baxter
16-09-2015 08:30 PM
