Esc Cos Crank Sensor
Just got a lovely new CPS from the boys at MSD and its getting fitted by me on Sunday.
Whats the correct gap between the end of the sensor and the crank pulley lugs ?
Is this gap fixed by the mounting bracket or do you need to adjust it manually ?
ta
ta
The mounting bracket is held by two 10mm nuts that have slightly larger holes than normal so you can move it to adjust, between 0.6-1.0mm.
The sensor secures to the bracket by the two 8mm headed bolts that pass through the metal flange part of the sensor.
Mark RS
12-10-2015 06:01 AM
