Swapping morettes
Swapping morettes
At the moment i have morettes on my Cos, i have a set of standard headlights in my shed and i want to see what i prefer. I am a total novice at anything cars how easy is it to swap do i have to change the bulbs etc
The morrettes have a separate wiring loom, they are easy to disconnect.
Once you have them off, they are no different gettin the bulbs out to
a normal headlight.
There is four nuts on the back of on each unit, and remove the front grill
at the same time, this is just two screws in the slam panel..
you might have to remove the side lights in the wings aswell, not sure
but thats easy just a pull spring behind the headlight.
Hope that helps..
Al..
a normal headlight.
Hope that helps..
Al..
Originally Posted by cheftony1
Am sure you have to take the bumper off too !!
Steve Escos
01-10-2015 06:57 AM
grishenko45
09-09-2015 12:58 PM
