Knocking/clicking noise
I have a problem with my Escort, when i drive slow i can hear a quite loud clonking noise, its coming from the drivers side front wheel. It seems like its getting louder. Its seems to happen at the same rotation if you no what i mean
Any ideas before i take to a Garage?
Re: Knocking/clicking noise
Just went out with a man from the garage, it only happens when going slow, the minute you tap the break it stops
mine is ok turning, thats what the garage bloke said, he was driving it and said it should do it now and turned sharply into a bend, No noise at all.
We swapped and i drove, i slowed down to 5 mph and you could hear it clonk clonk lol
Mine varies with speed so must be the CV / drive shaft. Bloody thing.
Seen CV joints on ebay for £50 that say their not refurbs .
Is it a big job too change these things? I wont be doing it, they looked like they didnt really wanna do it? Its going back tomorrow to get properly looked at and diagnose what it is.
haha its not just mine thats done it then,my drivers side front went on the way back from ford fair whilst rolling in traffic i could here it clicking and by the time i was on the m1 it was cloncking had to do 50mph all the way home as i could feel it through steering wheel, checked my wheel nuts as i wasnt sure it could be shaft as it has only done 500mile and i already replaced engine mounts,mind you it does sit on its arse probably to much stres. that was one long drive home
IVE AN ESCORT COSSIE-a few years ago( id only had it for a week or so) and it developed a knock /tapping on the drivers side on cornering, i looked at everything possible ------------THEN I NOTICE THE MASSIVE EXHAUST ON THE CAR (LOOKING AT THE TURBO AREA!!!)-I ALSO THOUGHT THAT LOOKS CLOSE THE THE CHASSIS AND THE STEERING KNUCKLE!!!2M ONE SIDE AND 8 MM THE OTHER (YES THE EXHAUST IS BIG!!!) ON CORNERING THE EXHAUST WAS JUST TOUCHING THE CHASSIS ENOUGHT TO GIVE IT A KNOCK-----------REASON!!!!!!TURBO WAS A TAD SLACK ON ITS BOLTS!!!!! AND HAD DROPPPED!!------NOTHING TO TO WITH ENGINE MOUNTS OR DRIVE SHAFTS ETC ETC-----HAVE A LOOK AT YOURS FIRST------------------
Originally Posted by NEIL A
Is the car running Ap's i had a similar knocking noise that went away when you tapped the brakes , turned out to be the pad retainer clip has jumped out the little retainer holes alowing the pad to move around.
Cheers I'll get them to look at that as well
It was the CV joints making the noise, the left is slightly noisy so there gonna change both
Mines in for this thursday 6th , getting a starter motor fitted as well.
Cheers.
Cheers.
Cheers.
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
