Speaker wiring
Speaker wiring
I want to replace the existing speakers in the front door with new components. The only problem is I've got nowhere to put the crossovers and would rather have them under the dash as they are adjustable but there is only one set of speaker wires to the door and I can't see how I can get another set through for the tweeter.
Hi tan
Hope the cars ok?
Im sure that if you remove the rubber casing that contains the wiring into the door from the pillar that you would be able to get another one through there
Hope the cars ok?
Hi Martin,
The cars going fine and its good to have same nice weather at last
Did you manage to get your's sorted?
Trouble is its a plastic connecter and the wires terminate at one end and the same at the door and it makes the connection when you twist it together so I can't see how I can get any more wires through it?
Originally Posted by tan
Hi Martin,
HHHmmm struggling with that one as had something similar on my old fiesta, sorry cant suggest anything else to you
Mark RS
12-10-2015 06:01 AM
