Possible Front diff problems???
Old Jan 14, 2004 | 09:00 AM
Paul Eggleton's Avatar
Paul Eggleton
Default Possible Front diff problems???
Not sure whether I have a problem with my front diff or not. At very slow speeds, and turning the wheel e.g parking , I get a small knocking noise, worse when cold. I know the car had a new steering rack before I had it and if you turn the wheel when stationary there is no noise, so i think this is fine. Also at speeds on crap roads it does seem to follow the bumps more than i would have thought was normal (it is lowered with poly bushes up front and std rims). When at speed or cornering hard, it all feels fine. Are the above just 'features' of the car or does it sound like somethings not quite right. Whats the best way to check it out.
ta
Paul
Old Jan 14, 2004 | 10:46 AM
Fozy's Avatar
Fozy
Sounds like ya lower arm ball joints are knackered. Mate had a similar thing happen to his.
Fingers crossed it is and not ya diff!
Old Jan 14, 2004 | 10:49 AM
Paul Eggleton
Thanks Foz, It's due the MOT this week so that may show up, I'll check while its on the ramp.
Paul.
Old Jan 14, 2004 | 10:55 AM
kjc300's Avatar
kjc300
You sorted that out yet Paul, cos I think I've got the same!!!! Changed both front wheel bearings the other day - so it's not that(LHS was F*&^%$!!) Drive shaft seems OK. £53.69 from fords for a new tca - hoping it doesn't come with bushes!! I got poly ones too!!
Old Jan 14, 2004 | 11:03 AM
I've got the same problem with mine, a friend at Ford said it would probably be the TCA, especially if they have never been replaced.I've just had the NS done and you can get the arm with out the bushes.Hope it helps.
Old Jan 14, 2004 | 11:04 AM
kjc300's Avatar
kjc300
Mint, cheers mate!!
Old Jan 14, 2004 | 01:14 PM
Paul Eggleton
Guys, I'm going to scc to pick up a headlight tomorrow. Rich says I can stick it on the ramp and check it out. Hopefully TCA's. Maybe time for some adjustables from Zoo. Will let you know
Paul.
Old Jan 16, 2004 | 06:44 AM
Paul Eggleton
Got it on the ramps at scc last night. No obvious problems. Nothing loose or worn. They suspect it could be the suspension top mounts, or the new rack that was fitted a few months ago maybe shagged????
I'll change the top mounts first I think.
Paul.
Old Jan 16, 2004 | 08:03 AM
kjc300's Avatar
kjc300
I might get round to doing my tca's - got them sat in the car!! Mine only does it when turning left, it was doing it before I changed both front wheel bearings - still doing it now. still pissed off about the ford tca's though £48 for the left, £112 for the right!!!!!!!
Old Jan 16, 2004 | 09:46 AM
THE RADMAN's Avatar
THE RADMAN
could well be the top mounts,ive replaced several of them,weak as *uck
Old Jan 16, 2004 | 09:54 AM
I've just been quoted £135 inc vat for that part,thats complete with bushes.They do the NS without but the OS comes with.They couldn't even tell me what the difference was between them.Bloody Ford.
Chris.
Old Jan 16, 2004 | 11:27 AM
THE RADMAN's Avatar
THE RADMAN
ive got some bare t/c/arms if anyone needs any,the b/joint rubber dust covers were damaged on removal though so you'd have to reuse your own
Old Jan 16, 2004 | 05:22 PM
kjc300's Avatar
kjc300
Burton power still have them listed as £57!! in the 2003 catologue.
Old Jan 16, 2004 | 11:56 PM
The Youth.'s Avatar
The Youth.
check the front prop front u/j they fail due to heat from the exhaust and cause these symptoms, well they did on at least 3 4x4 cossies that I know off!!
steve
Old Jan 17, 2004 | 10:39 AM
kjc300's Avatar
kjc300
Youth - YES I KNOW!!!! Quite scary when one of them fails @150+mph!!!!
Old Jan 18, 2004 | 05:23 PM
Can you buy the dust covers only for the TCA's? One of mine has split but it is still good
Chas
Sep 21, 2015 08:57 PM
C2 MAK
Aug 20, 2015 09:46 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
COLEYST200
Aug 3, 2015 08:55 AM
