P8 possibley causing backfire
Old May 20, 2007 | 07:08 PM
AJC's Avatar
AJC
Default P8 possibley causing backfire
when i bought my escort the ECU was nakered, car back fired when on over run when you dabbed the accelerator.
any how, its started to do it again
any one know where to get P8 re boarded as such?
Old May 20, 2007 | 08:07 PM
robbieg's Avatar
robbieg
P8's very rarely go wrong,how did you remedy the problem last time??
Old May 20, 2007 | 09:51 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
He bought another P8 off me
Old May 20, 2007 | 10:56 PM
THE RADMAN's Avatar
THE RADMAN
are you running normal coil ? or dizzyless?
Old May 23, 2007 | 12:32 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Does the rev-counter jump about at the same time as the back-fire?
Old May 23, 2007 | 12:38 PM
Rolls's Avatar
Rolls
From what i've read on here, doesn't a rev counter playing silly buggers, and the car missing tend to point to the CPS?
Old May 23, 2007 | 12:51 PM
cossymad's Avatar
cossymad
That's what I was thinking...
Old May 23, 2007 | 05:40 PM
AJC's Avatar
AJC
THE RADMAN
im on coilpack
Mike Rainbird
i dont think so, will check again tonight and watch it, i am going to uplug the ISCV as its idling high too
Rolls
CPS is brand new,
also, on the SECS monitior, everything is fine
thank you fr the help so far
Old May 24, 2007 | 08:26 AM
Mike Rainbird
Caraholic
If it's idling too high, that indicates an air leak to me - check to make sure the FPR hose hasn't blown off (or any other hose). This can cause high idle and misfire (as the fuel pressure won't be rising with boost, so it will be running lean ).
Old May 24, 2007 | 11:56 AM
THE RADMAN's Avatar
THE RADMAN
are your ht leads well away from the map sensor? as this can pick up signals/interference from them
Old May 24, 2007 | 04:55 PM
AJC's Avatar
AJC
Mike Rainbird
thank you mike, but i pressuried the boost system and got no sign of an air leak except the slight hiss from amal valve
THE RADMAN
not really, im on coilpack, they run through inlet manifild, under top boost hose and next to header tank where the coilpack is, they always been there and this problem has only just started.
they are over 6 inch away id say
Old May 24, 2007 | 06:37 PM
bigpower's Avatar
bigpower
Thought you were rebuilding her???
Sounds strange?
Old May 24, 2007 | 07:25 PM
dave cos4x4's Avatar
dave cos4x4
inlet manifold may have a leak in it.
Old May 26, 2007 | 09:28 AM
AJC's Avatar
AJC
bigpower
that problem sorted now
dave cos4x4
tested it for pressure dave, no leak
Old May 27, 2007 | 11:18 AM
DENNIS's Avatar
DENNIS
i had a burnt out ecu bord in my one when i got it, sent it to Engine Advantages who had it tested and replaced the faulty parts.
( incedently i had a missfire / cutting out, that turned out to be a fault in the loom that burnt the bord out but the rev counter used to drop off at the same time. sorted the short and the ECU and has been fine...
give Paul a call @ EA 01376 502 522
Old May 27, 2007 | 01:32 PM
AJC's Avatar
AJC
DENNIS
thank you, will do some more tests hopefully and if cant find a problem anywhere else then i shall call him
Old May 27, 2007 | 03:20 PM
DENNIS's Avatar
DENNIS
Originally Posted by AJC
DENNIS
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
rsturbo27
Sep 5, 2015 05:08 PM
