wiring diagram
1 Post
tbh, you done need a wiring diagram to remove it....
just trace the wires back from the unit.
there will be 3 that are connected into the car loom, perm live, switced live and earth. and 2 or 3 pairs (depending on model - sillouhette or managusta) that go inbetween the imobilsed circuits.
by rights a god instaler should have removed enough cable form teh original car loom not to be able to simply re join them together ( look for matching colours at each end )
you should be able sus out which is the fuel pump feed say and the power to the ecu...
its not a 2 min job, but again by no means a big job. always a lot easier removing than fitting as you have to sus out which wires to cut into
1 Post
you cant actually swap the brain of it, as its all epoxy resin sealed wherer all the black wires go into it, its back and about 6 " long and about 1.5" diameter cylindrical in shape.
Mark RS
12-10-2015 06:01 AM
