RPM-counter???
Old 09-02-2007, 08:37 PM
cossiemanden
DANISH cosworth abuser
cossiemanden's Avatar
Default RPM-counter???
Hi guys.
Does anybody know how to connect the orriginal rpm-counter to an aftermarket management system?
I know its the green wire that is the signal wire, but it still doesent work??
Any help would be nice
Thanx
Old 10-02-2007, 07:22 PM
Aftermarket ECM should accept a variety of inputs for ignition, and accordingly instructions for it will tell you which ECM feed to use, it may need re setting on compy to enable different output config, ask ECM maker for advice.
Old 12-02-2007, 02:54 PM
Dave Henshall
Dave Henshall's Avatar
you may need to short out the supressor that is used on the std setup - it is located near the coil - ans is screwed to the inner wing - it has just t woies to to - undo the multiplug and short out the wires inside.
Old 16-02-2007, 08:11 PM
cossiemanden
ok, will try that, many thanx
