RS500 intercooler fitting
Anybody know where i can get a fitting kit for my radtec rs500 intercooler or would i ba able to get it from radtec?
I know i need a 180deg hose for the water but can i use the other original hoses ? (big turbo escos non air con)
Thanx in advance
Thanx in advance
the radtec intercooler bolts direct to the chassis legs infront of radiator theres another pair of holes you just need a pair of bolts and rubbers the same as the radiator to mount it just put the bolt in hole and use a nut on the end as soon as the bumpers out the way your see the holes
Hi dave
Bloody was tight i can tell you!!and a real pain to fit, not as easy as Radtec said it would be. I even rung them to tell them what problems i had so nobody else would have to go through what i went through!!! but what a difference.....instantly noticeable from the standard unit and if i ever wanted to go mad the foundations are all in place............big if though as love it as it is
Originally Posted by redrsmk5
hi
did you buy the 60mm intercooler?? if so hope yours is easier to fit than mine was!!!
Dave
yes i have the collins ones...one of the first things i did mate
pewteRS
No problem matey just hope theres not too much difference between big and small turbo on this but i can tell you the problems i had if you want so you know what to look out for???? just let me know
pewteRS
Radtec 60mm cooler and alloy rad fitted on a esc cos. it won't fit if you put it on pro alloy bracket like above.
If you have a std rad you will have to move the mounts on the chassis rail backwards as the rad sits too far forward.
we've got a set of bolts on Ebay
http://cgi.ebay.co.uk/Intercooler-Ra...mZ320040010454
cheers
Daniel
I tried to fit my intercooler today and it dont mount direct to the chassis leg
I got the extra bolts and rubbers with collar but i need the small bracket like the one in the pic.
Anybody know where i can get these from coz my car is in many pieces
Its a Radtec 60mm one mate
I have just had a good search through some old threads and the Pro Alloy one comes with the bits needed so i'll give them a call tomorrow and let you know...................if not its a diy job
What did you lads do with your amal valve? (assuming you still have them)
Is there a bracket you can buy? Just looks quite messy with nowhere to mount it
I did mine last weekend and tbh it was quite straight forward too
I've not got an amal valve on mine but when do get one fitted i think i'll just stick it to the top of the cooler.
Cool, i thought the brackets were only for the Saff. might knock something up...cheers
Pewte: I know mate it was easy, i'd heard they were a nightmare to fit on the escorts. I think that's why i put it off for so long.
vdun01
Ford Fiesta
05-10-2017 08:14 AM
TrevCos
Modellers Corner.
24-08-2015 09:31 PM
