missing?
Old Oct 13, 2006 | 05:55 PM
Andy E's Avatar
Andy E
Default missing?
Started the small turbo this morning,pulls out the drive and jumps out to shut the gate ,bloody thing stalls and when i try and restart it its seems like its missing and wont rev up,checked plugs(not wet)pipes,air flow sensor,fuses,can hear the fuel pump going???????????any ideas please
Old Oct 13, 2006 | 06:08 PM
dave cos4x4's Avatar
dave cos4x4
is any part of the engine wet,wiring etc....
Old Oct 13, 2006 | 06:12 PM
Andy E's Avatar
Andy E
No but it was quite damp last night,when i start it and hold it full throttle it feels like its choking and missing,doesnt smell rich tho.had it set up by stu at blackpool oter week an it has been running great till this morning?
Old Oct 14, 2006 | 11:27 AM
Andy E's Avatar
Andy E
Have just put a new set of plugs in,no different,there is a funny smell from exhaust.None of the plugs were wet so i dont think its a coil problem.............any ideas much appreciated
Old Oct 15, 2006 | 12:39 PM
glancy2081's Avatar
glancy2081
does the car still have the cat in it it might be that it has broke up happened on a car a had once or fuel filter blocked
Old Oct 15, 2006 | 12:46 PM
Azrael's Avatar
Azrael
In my case this kind of behaviour was dirty ECU multiplug. But it may be any sensor - cranskshaft sensor, MAF something like this.
Old Oct 16, 2006 | 11:41 AM
Andy E's Avatar
Andy E
The cat is still on and sometimes i can hear it rattling so it could well be the problem,pain in the arse
Old Oct 16, 2006 | 02:01 PM
Dave Henshall's Avatar
Dave Henshall
if its rattling, its definately fooked - get a mongoose fitted
Old Oct 16, 2006 | 04:51 PM
Andy E's Avatar
Andy E
Its a bit unfortunate that i have a year old magnex on at the mo and you cant buy a cat replacement pipe apparently on this application so if it is the cat then i will need to get one made up.
Old Oct 16, 2006 | 05:26 PM
Chris and Dawn's Avatar
Chris and Dawn
Andy i've got the standard cat section that came off mine when i put the stainless on if you want to to try it.
Chris
Old Oct 19, 2006 | 07:30 PM
Andy E's Avatar
Andy E
As it turns out it was condesation/water in the fuel,new fuel filter fitted Wonder whats next
Old Oct 26, 2006 | 08:41 PM
glancy2081's Avatar
glancy2081
YOU DONT NEED TO BUY A CAT JUST TAKE THE CAT OFF THE CAR CUT THE TOP OUY OF IT TAKE THE CERAMIC PART OUT AND WELD THE METAL BIT YOU CUT OFF BACK ON AND JOB DONE
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fil
Sep 30, 2015 12:08 PM
Fiddy
21
Sep 29, 2015 06:10 PM
oldskooldanrst
Sep 27, 2015 04:02 PM
