any of yous got an engine monitor?
hi do any of you guys have an engine monitor in your cars?im thinking of adding one to my escossie and want to know how accuratte the are.what make do you have and what did you pay?
and how much did yous pay for your monitors respectivly?do you think adding this would do away with the need to add gauges?
Monte Geek
Mate get a Secs monitor
http://www.randbmotorsport.co.uk/sho...?ProductID=294
The Pectel monitors are very hard to come by as they haven't been made for years if you do find one expect to pay Ł4-500 for it
Testing the future
Originally Posted by Paul Ripley
They give you information from the ECU about the engines sensors
pectel monitors work by reading a datastream from the ecu that contains information on the voltage, boost, rpm etc. can also datalog and store peak data information
this can also be done using a laptop or carputer with software developed by RPLab that is available from Stu @ MotorsportDevelopments
the SECS monitor just piggy backs onto the ecu multiplug and does it's own analogue to digital conversion of the ecu inputs. to be used as an indicator and fault finder only. can display peak data, but has no datalogging.
if there is sufficient interest RPLab could manufacture 'pectel' style monitors brand new for less than used genuine ones. they would need to manufacture a minimum quantity of 50 to make it worthwhile.
JoeyBoyden
18-08-2015 10:52 PM
