Oil modine filter arm question
I've fitted this in order as shown above but the hole on the arm (9)doesn't locate to the one on the engine mount arm. If I undo the nut (10) it will loosen up enough to locate the engine mount hole and I can screw in the holding bolt, then do up (10) again.. just wondered if this was a common problem or whether I'm doing something wrong as the last thing I want to do is fit this all up and it pisses out oil from the seal (12)
