removing headlights
removing headlights
can anyone tell me the correct way to remove the headlights from my escort cosworth? i want to upgrade the headlamp bulbs so i need to change them and also put in bigger cables to carry the extra current via a set of relays. thanks
tony. [/img][/url]
tony. [/img][/url]
Monte Geek
Un bolt the center grill (4 bolts) then pop it out from the headlights
Pop out the indicators and fog lights and undo the bolt on the bottom of the headlight
Pop out the side lights then undo the two bolts on the headlight and it will come away
Steve Escos
01-10-2015 06:57 AM
