Oil breather fitting
Monte Geek
Yes this old chestnut
Ok I want to fit a Bailey oil breather to my new Escort engine and I just want to make sure I'm thinking this through right as there are a couple of bits I'm not sure on. I'm not wanting to use the cam cover breather outlet.
Ok say so I need an outlet to screw in to the threaded hole under the turbo. Which I don't have a pic off.
An outlet to bang into the hole the kidney box was attached to A.
Then as I have a big wing sump I use a aeroquip bend to screw into this? C
What then happens with the original oil return pipe B Blank it?
Monte Geek
Was just talking to Adamski ()
Using the gasket (19 arrowed) from ford and making a blanking plate to seal against it. It looks from that pic like the tube will come out after you unbolt the two bolts
Monte Geek
Hate to say it but thanks Adam
Franco will appriecate this aswell as he was all set to remove his sump to sort this but then again Franco removed his whole front bumper to change his indicators
mental note:-
Fri Jul 07, 2006 11:45 pm PAUL SAID THANKS
I'm glad you listened to my phonecall yesterday.............
THICKO!!
PS pop outside & undo the 2 grub screws on the old return hose, then....................
You can post a BIG FAT APOLOGY saying Franco i right IT WONT COME OUT!
Fucking nudger!!
THICKO!!
Fucking nudger!!
Originally Posted by adamski frst
at the end of the day i was right, and my idea is best
I told him i was doing all that over the phone Friday evening, even bloody down to using the gasket!!
Some bloody people! No gratitude!
Ps you still need the sump off!!
Look here for the exact description and diameters of the pipes.
https://passionford.com/forum/viewtopic.php?t=103270
mrmann
20-08-2015 11:24 PM
JoeyBoyden
18-08-2015 10:52 PM
