compresion struts
compresion struts
i think im correct in thinking that the comp sport compression struts bolt to the existing anti roll bar mounts, but what i was intrested in is what advantages/disadvantages changing to these will have on a road car, the main reason im thinking of using struts insted of the roll bar is to stop the bloody down pipe moving on to the roll bar , any coments would be welcome thanks andy
there are LOADS and LOADS of threads about this everywhere
just look them up and they'll give you the big rundown of what you need to know
but, in essence, the compression strut moves the wheel back/forward in the arch and you can put the wheel where you want
if you run wihtout the bushes you also get less play
