small turbo lambda sensor code...
Old Jun 23, 2006 | 12:07 PM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Default small turbo lambda sensor code...
Went to fords for a new lambda sensor and was given the code 1669758
anyone know if that is correct as ive read on here that the st/bt sensors are different but ford only had the 1 code
cheers
Lee
Old Jun 23, 2006 | 12:37 PM
sailorbob's Avatar
sailorbob
The marking on mine is YB1380 and it's made by NTK in Japan if that helps.
Old Jun 23, 2006 | 01:51 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
no ford are wrong there are two and if you give them your reg you should be able to get the correct one!!!!! i did this 2 weeks ago!
Old Jun 23, 2006 | 02:51 PM
robbieg's Avatar
robbieg
I went to ford for a new small turbo one yesterday,ST/BT are different
ST was actually £60 cheaper!!But none in the country at the mo and are on back order will take 1-4 weeks---try woodford he has other sources!!
but the code you were given is right
Regards Robbie
Old Jun 23, 2006 | 03:19 PM
sailorbob's Avatar
sailorbob
http://www.ntklambdasensors.co.uk/ma...ntk.htm#prices but try and make sense out of the years
Old Jun 23, 2006 | 04:17 PM
robbieg's Avatar
robbieg
Just been onto woodford garage--he sells NTK lambda sensors--is insistant that S/T and B/T are the same.NTK website as above also indicates this.Also are £99 rather than £143 from Ford.
Old Jun 23, 2006 | 04:51 PM
THE RADMAN's Avatar
THE RADMAN
thread sizes are totally different mate
Old Jun 23, 2006 | 06:08 PM
Rene's Avatar
Rene
6-7 th month in 1994 there was a change in finishcodes so 2 different types of small turbo esccos lambda's ... so make sure u have the build month of yours correct
Old Jun 23, 2006 | 07:30 PM
adamski frst
yes just checked my box the finis is correct and as said there are 2 sorts for the small turbo!!!! give them your chassis no or reg no!!! they WILL give you the right one!!
Old Jun 23, 2006 | 09:25 PM
THE RADMAN's Avatar
THE RADMAN
wouldnt bet on it
Old Jun 24, 2006 | 03:35 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
fuck this for a laugh
mine was built in november 1995, so which one do i need?
Old Jun 24, 2006 | 08:18 AM
adamski frst
same finis as me then they said the later type was for the 96 ones i'm sure
Old Jun 24, 2006 | 08:31 AM
sailorbob's Avatar
sailorbob
You can borrow mine to see if it cures your problem if you want, it's sat in a box in the garage at the moment.
Old Jun 24, 2006 | 02:48 PM
adamski frst
you can buy my old one if you want i replaced mine thinking it was the problem and it was the airflow metre so have the old one here in the box up to you i dont want fords £143
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Cosnada
Aug 27, 2015 09:15 AM
IAN RS2k
Aug 18, 2015 07:51 PM
muz
Aug 16, 2015 12:57 PM
