Symptoms??
Symptoms??
What kind of symptoms would I be suffering from in my small turbo EsCos if 1:- my Air Flow Meter was fooked and 2:- if my coolant temp sensor was knackered?
Generally poorer running, higher fuel consumption, poor idle. The eec does a fairly good job at coping with these sensors when they've failed but it'll be far from perfect. A code reader will tell you if the eec thinks the sensors are faulty.
Lambchop
83
20-02-2021 02:34 PM
Sheepdisease
30-08-2015 09:11 PM
Cowboi
12-02-2006 07:41 PM
