help with rs500 cooler fitting, pro alloy PLS
all i need to know is the modification plate that bolts to standard
radisator mounting, and then the cooler and rad bolt to underside of it
is that correct, and am i right in thinking 1 rubber on each end of both
rad and cooler, cheers peeps
https://passionford.com/forum/viewto...er=asc&start=0
An entire thread about the exact same thing although I also bought the radiator with them.
Originally Posted by AJC
Damo V
you are my hero
so the sleeve that the rubbers come on are not use?
thats why i got confused
cheers
p.s which hole centres did you use?
the closest or furthest from the non tapped hole
thank you very much
you are my hero
cheers
thank you very much
You can see from my first pic, I have put the bigger gap (from centre hole) towards the front...
It fits perfectly on mine, though I know others have put the bigger gap to the back...
