Phase sensor?
Old May 28, 2006 | 02:06 PM
lamar69er's Avatar
lamar69er
Default Phase sensor?
Should an Escort Cosworth start without the eletrical connector on the dizzy plugged in? I presume this is the conection for the phase sensor?
Is there anyway to test to see if the phase sensor is working? and what symptons would you be getting with a faulty phase sensor?
Old May 28, 2006 | 03:12 PM
costina's Avatar
costina
Live long and prosper!!
no it won't start mate
This took me three days to sort when fitting my lump into cortina
The connection was bad causing no start
Old May 28, 2006 | 03:19 PM
lamar69er's Avatar
lamar69er
But what about if it does start?
Old May 28, 2006 | 05:15 PM
Damo V's Avatar
Damo V
Sorry but it will.... maybe if still using rotor and cap you are right BUT on my LT car which is now running dizzyless I had a faulty phase sensor and car started, by pure LUCK... i.e sometimes it wouldnt and would backfire or the engine would advance (like it was under hydraulic pressure) .. New phase sensor, starts first time all the time strange I know but true
Yes the phase sensor can be tested, though not exactly sure how (multimeter etc)
Old May 28, 2006 | 06:13 PM
lamar69er's Avatar
lamar69er
Well my car starts without having the electric plug connected to the dizzy! which makes me think the phase sensor is doing diddly squat!
surely the ecu should go nuts without this plugged in????
Old May 28, 2006 | 06:25 PM
MaxCos's Avatar
MaxCos
hi
can send technical diagnosis info to test all sensors (1.5mb for adobe)
if anyone want
MAX
Old May 28, 2006 | 06:26 PM
lamar69er's Avatar
lamar69er
Originally Posted by MaxCos
hi
if anyone want
MAX
yes please... can you email it me:
lamar69er@hotmail.com
Old May 28, 2006 | 06:35 PM
MaxCos's Avatar
MaxCos
just send
MAX
Old May 28, 2006 | 06:39 PM
lamar69er's Avatar
lamar69er
just send
MAX
Nice one! great stuff...
Old May 28, 2006 | 06:58 PM
MaxCos's Avatar
MaxCos
MAX
Old May 29, 2006 | 10:08 AM
Gregs's Avatar
Gregs
4x4 engines will start but 2wd will not, something to do with 4x4s having extra sensors to compensate for 1 going down
Old May 30, 2006 | 06:52 AM
Dave Henshall's Avatar
Dave Henshall
Old May 30, 2006 | 08:19 AM
Damo V's Avatar
Damo V
Dave did it cure yours too??
Old May 30, 2006 | 10:22 AM
Dave Henshall
not yet, just found that after reading the other post,
found one on ebay, brand new 23 quid
cheers
Old May 30, 2006 | 12:10 PM
lamar69er's Avatar
lamar69er
Yep just about to order one! better to be safe than sorry!
Old Jun 1, 2006 | 01:42 AM
mxquattro's Avatar
mxquattro
Id love a copy of that if I could too
bob@maxboostracing.com
thank you!
Old Jun 1, 2006 | 08:17 AM
trotty's Avatar
trotty
maxcos,
could you e mail me the testing info too please?
trotty01@hotmail.com
cheeRS.
Old Jun 1, 2006 | 02:04 PM
MaxCos's Avatar
MaxCos
hi
trotty,mxquattro mail sent
MAX
Old Jun 9, 2006 | 07:48 AM
Dave Henshall
fitted it last nite - the old one had lost its magnetism from its megnetic base - it was gapped right though,, and its only 3 years old and covered 10K - new one in and give it a whirl - starts with hardly turning over now - this must have been bugging it for some time, combined with the porous head AND BOTH the fooked starters AND THE FOOKED battery - fingers crossed it stays ok for a bit...
the old one.....
and while i was at it...
changed the last remaing rubber coolant hoses for the roose ones that i ordered a month a go and never got round to fitting - extremely good fit on these i have to say, better then the samco i dare say....
Old Jun 9, 2006 | 04:38 PM
costina's Avatar
costina
i'm using lL6 that explains why i said NO
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
