idle valve and boost valve on big turbo
Anyone know the duty cycle and frequency on the idle valve and the boost valve on the big turbo motor? Im putting in an aftermarket engine management system
thanks!
bob
thanks!
bob
I’m not shore if the idle valve on an Escort is exactly the same spec as a 2wd Saff but I use 40Hz for these solenoids using an Autronic ecu. I haven’t run the stock boost valve threw the Autronic so have no idea on that one.
I was thinking of using that one, ive heard a lot about it. I think my EMS will do it though, so I might use that. If it doesnt work the way I want it to, Ill use the HKS.
Matt Baxter
16-09-2015 08:30 PM
Escortdriver1
31-07-2015 02:36 PM
