help!
Apr 3, 2006 | 08:34 PM
help!
car will not rev past the point of coming "on boost" but revs fine up till then, proper cut out at say 3k think its a sensor? any idears?
escort cos P8
it doing my head in!
Apr 3, 2006 | 08:39 PM
Łk is Limp mode I think.... try disconnecting battery for a day see what happens, but yeah you got a problem of some description... Do you still have the loom plugs by power steering tank?
Apr 3, 2006 | 08:44 PM
no they have been cut out recently,
battery has been off for the last 4-5 month!
dissconnected the phase sensor so it would go in to limp home mode and it did change for the worse
Apr 3, 2006 | 08:51 PM
Has it been running rough ever since you reconnected the battery??
If not then disconnect it for a while again
Favourite would be crank sensor IMO..
Apr 3, 2006 | 08:54 PM
ok thanks for that,
will dissconecting it while running show this up?
Apr 3, 2006 | 09:21 PM
I don't think it would run at all without crank sensor...
Apr 4, 2006 | 08:02 PM
if i was you buddy id check tps or afm..apt or maybe the hm.. if your stuck i know a man who can.
Apr 4, 2006 | 08:20 PM
Quote:
AFM+Air Flow Meter? ... What on a LT??
Apr 4, 2006 | 08:35 PM
whys everyone talking in short hand,lol, oh no,now im doing it
Apr 6, 2006 | 07:41 PM
can someone translate?
Apr 6, 2006 | 09:47 PM
Apr 8, 2006 | 02:23 PM
