major cossie problems!!!!!!!!!!
#41
1 Post
when u turn the key to position 2, does the fuel pump run for a few seconds then stop...? (this should happen)
have you tried removing a plug and leaving it pluged into the ht lead and let it sit on the rocker cover and turn it over, do you get a spark when its turning over.?
#42
Re: cossie
Originally Posted by roscar588
the mechanic has gone through the whole fault finding ecosse guide step by step, nd nothing even ford are confused? i had a ford engineer pop round to take a look even he didnt suggest anythin except wot weve already tried??
#43
Re: cossie
Get it to someone who specialises in them, you are going around in circles..
#44
Had a non starting problem on mine turned out to be Lambda sensor. the wiring was faulty. dissconected it and it started worth a try as it is a 2 second job.
I think you way forward if you want advice on here is to state everything you have tried and with what results you have found. ie
can you here fuel pump prime when you switch ignition on
have you got fuel at rail / have you got spark etc etc
The boys on this site know there stuff and will help you out but you need to state correct information to get anywhere. Goodluck getting it sorted it will be a great car when sorted
#45
cossie bites the bullett
just a quick update, by the looks of it the cossie is gonna be trailered by graham goode. up to their place and have the works done by the pros??
shed loads of money again?
but at least it will be running again! i hope
#47
Re: major cossie problems!!!!!!!!!!
my cossie is driving me mental, bought it in november and all was fine, 2 weeks in, had to change speed idle control valve, then headgasket went!!!
so thought while im there i ll get it built to a nice spec, and built with durable parts...cometic wrc headgasket etc etc......
it is 290bhp, on greens a large turbo conversion and a A1 rally sport chip. All done by the above,
however now the car wont even start...fuel is just pouring into the engine...hence flooding, have changed all sensors, checked all wiring, and am currently awaiting results of ecu and injectors tests?? its been sittin on my drive for 4 months, it cost me £20k, and ive already spent £3k on parts and labour.. im at the end ?? help me please
these cheesy buggers often break down and leave random problems..
easily to disconnect and try and start...
then next thing you do ... buy new sensor
Thanasis
07-09-2015 07:33 PM
