fitting new fogs
fitting new fogs
To save me ripping the front of the car off tonight....is it best to remove headlamps...or go underneath....Id probably work it out...but best ask you guys as someone will spare me the agro.
their is a spring clip on top of the indicator you need to push that up so you need a long thin screw driver or the like then the indicator will pop out. after that you can undo the clip on the fog light, you just pull the latch and gently slide the fod out of its ball joint type mounting!! took me flippin ages without damaging anythink!
good luck
good luck
Originally Posted by maxest
Fogs?!....... Pop the indicator out, then it just unclips! 2 minute job!
track.focus'd
12-08-2015 05:53 PM
sridgett
15
03-08-2015 07:26 PM
