Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Fuel system setup
Old Apr 16, 2014 | 01:50 PM
timsrs's Avatar
timsrs
Default Fuel system setup
Hi
i am running a 400bhp Yb in my MK1 escort, which is fed by a 044 fuel pump, which is being fed by a swirl pot, with a return back into the swirl pot.
The swirl pot is being fed from the main tank by a Facet redtop, then a return back into the main tank....
The 044 fuel pump is being fed from the ECU which on ignition 1 gives a small prime of fuel as does the facet pump...
My question is should the facet be started / run on ignition 1
Also the facet seems to be working hard rarther than a tick like when its under pressure...I am sure this is because its running a circuit which is open return back to tank, is this correct.....
Help or advise please.
Regards
Tim
Old Apr 16, 2014 | 07:13 PM
timsrs's Avatar
timsrs
anyone !!!!!!!!!!!!!!!!!!!!1
Old Apr 16, 2014 | 08:48 PM
sharky584's Avatar
sharky584
Shark conversions
hello mate im running the same setup at 405bhp i run the facet on a seperate live and switch and the 044 works as normal through ecu.
Old Apr 17, 2014 | 04:26 PM
timsrs's Avatar
timsrs
Thanks mate ....
Have you got a restrictor in the facet line on the return to tank.
Tim
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
155lee
Oct 27, 2015 04:55 AM
Dubs44
Sep 19, 2015 06:31 AM
truffleshuffle
Sep 10, 2015 09:35 PM
ST-170
Sep 4, 2015 11:02 AM
