Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
capri info needed
Old Aug 2, 2007 | 05:27 PM
vibrating_cake's Avatar
vibrating_cake
Default capri info needed
okay, i have a new ford capri (well not new, but new to me)
and was thinking about learning a bit about engine tuning, what does what etc, by actually doing it first hand.
anyway, i was wondering would
http://cgi.ebay.co.uk/MK-1-2-3-CAPRI...QQcmdZViewItem
this fit onto a capri's engine and mate with the exhaust going under the car, or would i have to have one made.
probably need someone with good knowledge of the capri's engine bay (mk3 btw) its for the right engine (pinto)
ta, neil
Old Aug 2, 2007 | 06:39 PM
ToGGoT's Avatar
ToGGoT
Is yours a 1.6 pinto, or 2-litre?
If its a 1.6, i doubt it'll fit.
ToGGoT
Old Sep 25, 2007 | 10:29 PM
SLIM's Avatar
SLIM
all pinto cylinder heads are exactly the same dimension wise, the only difference being the diameter of the inlet valves, the 4-branch will fit for sure f it is in fact capri item,
if you're running a 1600 pinto then to be honest i'd ditch it and get a 2.0 for the money you won't get a better power gain
if you're running a 2.0, use 2.8i v6 pistons and a 2.0efi sierra head with a well set up 38DGAS carb from a 3.0 then you should have plenty fun
Old Sep 26, 2007 | 05:59 AM
It will as said fit ok.
I too agree go for 2.0 to start with, I had a few 2.1(v6 pistons) in sierra's all auto's, the last with a 32/26 got around 135 bhp out of it.
You will NOT get anything approaching 15/20bhp gain from this manifold, expect around 5/8 if your lucky, but it will alow it to rev a lot better.
I had a HT head(injection) on mine was way better for it, used to get 38/42 mpg as well.
Don't bother with a 2.8 transplant as they are not particularly good, a tuned pinto will be way better/faster/easier to tune.
cos elle
Sep 1, 2015 06:48 PM
salsheikh
Alloy wheels and ICE for sale
Aug 20, 2015 12:33 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
salsheikh
Jul 30, 2015 08:45 PM
