Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
MK1
Old May 7, 2007 | 11:34 PM
Quincy's Avatar
Quincy
Default MK1
thinking of buying this fiesta MK1 but although i dont know much about fiestas and eveyone ive asked its either yes or no
its a 1.6
running twin 40 webbers
apprenly a lightend and balanced bottom end
been bored out
its runs havnt seen it move though cause of 3 flat tyres
ist red haha
£600 he wants for it
clean inside an all
and its got the round headlights not the sqaure ones
Old May 8, 2007 | 06:43 AM
Sounds like MK1 XR2.
1.6 is standard, check carefully as it is hard to get particularly egine buts now for these, x flow bits DO NOT FIT, as it is a 1.6 version of VALENCIA engine, ie fwd not x/flow although they look identical.
ps make sure it is a 1.6 and not boggy 1.3 tarted up!!
Old May 8, 2007 | 11:59 PM
Quincy's Avatar
Quincy
cheers mate
ill have a look mate
you reckon there must be summat wrong if its going for £600
Old May 9, 2007 | 05:18 AM
Hard to tell, I would take any work that you can't see like engine work inside with a pinch of salt.
Rust is obviously going to be the main concern at this age, there are a few and it is a few components that can be used modded from other engines like pistons, at £40 a set!!, if rebore needed etc.
Certainly worth a look IMO.
Old Jun 4, 2007 | 09:59 AM
Mr Sam's Avatar
Mr Sam
the 1.3/1.6 in the mk1's are x'flows
slightly different block to the RWD ones as they dont have the mounts on one side
£600 seems cheap though
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Oct 3, 2015 10:44 PM
Sep 28, 2015 10:05 AM
Tank Mike
Sep 26, 2015 08:07 AM
