Boa....type 9?
Do you know what needs to be done to the mt75/Dohc box is it a case of changing the shaft or modifying the bell housing to suit I.e is it mechanically done or does anything need machining, the reason I thought type 9 as they are so easy to pick up
Pick-up P100 Power!
Where abouts are you?
If you do the hybrid, because the mt75 uses an integral bellhousing you need to find an V6 4x4 box for the front part of the case and pull the rear off and swap it for one from a 2wd dohc. Beware its not that easy, you need specialist tools and the knowledge. Even then the ratios are not that great, and you best of swapping the gears for the ones from a 4x4 cos box. So really 3 boxes to make one.
I recently bought a T5 box, had it rebuilt with uprated bearings, new synchros and a new 5th gear and it was only 360 to have all that done. Plus the t5 will take alot more shit.
Edit: Should of mentioned that Type 9 V6 boxes dont last long on BOA/BOB they just break! A mate of mine says they are good for about 150bhp, dont know how true that is but he broke a few.
Resident Wrestling Legend
the gear ratios in the mt75 box are all the same other than the diseasal so the cossie box gives you no difference to the standard dohc box
you need the front casing and input shaft from the v6 box and keep the rest of the normal 2wd box, but the t5 is the best option for ratios
Pick-up P100 Power!
A quick google pulled this up http://www.super7thheaven.co.uk/MT75_Gearbox may be of use but no mention on the cossie box. I would trust Dojj, he is a Guru with this stuff.
