raidiator fans
Old Feb 4, 2006 | 01:11 PM
Rob493's Avatar
Rob493
Default raidiator fans
I have just fitted a rs 500 intercoler but now my fans are not working on the radiator is there anything i can check already checked the fuse and all the connections are fine.
Old Feb 4, 2006 | 01:27 PM
BMEP's Avatar
BMEP
Hi Mate,
There is a temp sensor in the radiator. If you un-plug the sensor, turn the ignition switch on so all your dash lights light up and then bridge the wires on the plug end (not the sensor), the fans should turn on. If they don’t then it will be either the fans fuse has blown or the fans themselves. If the fans start to work then the sensor would be at fault.
Old Feb 4, 2006 | 01:33 PM
Rob493's Avatar
Rob493
Thanks m8 i will try that just tried as u suggested and fans worked fine so must be the sensor thanks m8
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
simonmcf
Sep 22, 2015 08:40 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
