cosworth engine UPDATED 29.03.06
Old Feb 4, 2006 | 08:42 AM
ATM SPORT's Avatar
ATM SPORT
Default cosworth engine UPDATED 29.03.06
Cosworth engines
RS500 cosworth engine, fully rebuilt, with new motorsport 200 long studded block, polished and ported head, WRC head gasket, BD14 cams, WRC 8 injector inlet manifold and fuel rail, New T4 motorsport turbo, high torque exhaust manifold, high pressure oil pump with oil spray system, polished con rods, lightened and balanced crank, new water pump, big wing alloy sump, motorsport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, AP paddle clutch , all new seals and bearings, 6800 pounds SOLD ON PASSION FORD
mountune spec clubman GPA cosworth engine, fully rebuilt, with motorsport 200 long studded block, WRC head gasket, New motorsport turbo, high torque exhaust manifold, high pressure oil pump with oil spray system, lightened and balanced crank and rods, new water pump, big wing alloy sump, motorsport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, AP paddle clutch, 4500 pounds
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
