COSWORTH VIBRAITION
I HAVE A REALLY BAD VIBRATION THROUGH THE WHOLE OF MY 2WD COSSIE WHEN I GO ABOVE 90MPH COULD ANYBODY SHED ANY LIGHT ON THE PROBLEM BECAUSE ITS STARTING TO GET ON MY NERVES
To check if prop shaft is defective, lift rear of your car, secure it, start your engine on 3 or 4 on iddle speed.
And with good spoot light, look on your propshaft, (on the middle of each half part) if you see strong vibrations or not.
Regards.
Claude
Regards.
Claude
Adam Graham
Sep 6, 2015 06:04 AM
