what wud cause??
4x4 saph steamcleaned engine all plugs and looms full of water dumping fuel in like nothing i have ever seen ...runs alot better with map disconnected its on greens with 3 bar i presume
new map i'm thinking!!!!!!
co% is 8 - 11 heavy black smoke .. plugs were soaked in fuel
Wouldn’t it be wiser to first disconnect all the sensor plugs/looms and dry/blow out all the water and then see what happens? If the over fuelling was caused by a sensor, then id look at the coolant temp sensor first. It’s located on the intake side of the head right at the back near the dip stick
roybacer
Aug 15, 2005 12:20 PM
