Disturbing email from Pace products ?!
Originally Posted by Oranoco
It's a poo response but the intercooler is the bollocks. I wouldn't have anything else in my Escort
Charge carrier been welded to accomodate dump valve you see, not sure how the fitting kit works or if I even need it
Originally Posted by Katie
fantastic
looks like the sales exec has gone on holiday and some plonker called dave's on email reponse duty
PassionFords Creator
Im actually laughing here at YOU LOT...
The substance passing through that pipe and into the plenum is AIR (And often oil..lol)
It cannot be deemed a CHARGE until it is mixed with FUEL, therefore that pipe is just an "air carrier" that crosses over the camcover, so i suppose it might be accurately termed a "crossover pipe" but it will NEVER be a CHARGE carrier as it can never carry a charge unless it has fuel in it. (Some 5th injectors can be mounted here, but thats not factory configuration)
I stand corrected, the reverse "air-carrier" is a vital part of the system, instead of the stock item which sways the other direction
still need one though...
Similarly, if I asked you what OS you run on your PC or what a GUI is, would you know? But to a computer expert, those terms are well known and a very basic part of what you use every day!!
