Injectors
Old Feb 3, 2006 | 04:21 PM
cosworthbg's Avatar
cosworthbg
Default Injectors
Are the std injectors for big and small turbo escorts the same???
Old Feb 3, 2006 | 04:31 PM
SAM_COSWORTH's Avatar
SAM_COSWORTH
Default Re: Injectors
Are the same, a Blue dark color
Old Feb 3, 2006 | 06:11 PM
Dave Henshall's Avatar
Dave Henshall
no, the saph 4x4 and large turbo escos are the same (dark blue), the small turbo ones are dfferent again.
Old Feb 3, 2006 | 06:43 PM
escossie560's Avatar
escossie560
small turbo are high impedance and a slightly higher flow rate than the large turbo low impedance
Old Feb 3, 2006 | 07:49 PM
kennyA's Avatar
kennyA
On the Bosch list, the small turbo escort injectors are shown as,
14.25ohm and 222.2 cc/min.
Is this correct?
Old Feb 4, 2006 | 12:24 AM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
the std small turbo ones are black they can only flow up to 280bhp then you have to change the fuel reg...
Old Feb 4, 2006 | 09:11 AM
RS 1800's Avatar
RS 1800
Are the T25 injectors the same size as the T35s? Length, width, in other words would they fit T35 fuel rail? Or are these side feed as most other Fords runnin EEC managment?
Do you have the bosch part no. for the T25 injectors?
Old Feb 4, 2006 | 09:16 AM
RS 1800's Avatar
RS 1800
Found the no; 0 280 155 012
Old Feb 4, 2006 | 01:35 PM
kennyA's Avatar
kennyA
RS 1800
My injectors are original T25, V92HF-AA, they are 75mm long. I checked some large turbo injectors, greens I believe, they were 80mm long.
Old Feb 4, 2006 | 05:54 PM
Damo V's Avatar
Damo V
different fitment at fuel rail.. i.e. LT and ST use different rails
Old Feb 4, 2006 | 05:56 PM
RS 1800's Avatar
RS 1800
Ok, thanks
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
