Concours 400bhp 3dr Sierra Cosworth
Old Feb 3, 2006 | 10:45 AM
Ian3dr's Avatar
Ian3dr
Default Concours 400bhp 3dr Sierra Cosworth
Decided to sell my 3dr.........
I have had the car coming up for 6 years this year. It was 39'000 miles when I got it, and is now showing just over 50'000. It has been exstensivly restored top to bottom, every nut, bolt washer clip and grommet is new! It is the current Gold Cup winning car for the RS owners club for best modified Cosworth 2004 and 2005, Ford Fair winner 2004 and 2005, and National Day winner 2005.
The SCS engine in the car has done approx 5000 miles.
I am not desperate to sell the car, so it aint going to be cheap! Over the last 6 years I have thrown over £50'000 at the car to make it what it is today. It currently has the highest agreed value with the RSOC.
Spec.
ENGINE
200 COSWORTH BLOCK
STANDARD STEEL CRANK, STANDARD STEEL CON RODS
GENUINE COSWORTH PISTONS
LOW COMPRESSION (7.6:1)
HIGH PRESSURE OIL PUMP
BIG WINGED SUMP (1 litre extra)
WRC METAL 4 LAYER HEAD GASKET
LONG STUDDED
4X4 POLISHED & PORTED HEAD
HARVEY GIBBS CAMS
KENT ADJUSTABLE VERNIERS
PORTED INLET MANIFOLD AND PLENUM
INLET MANIFOLD ‘O’ RINGED
4X4 EXHAUST MANIFOLD
GT28 ROLLER BEARING TURBO WITH MODIFIED T34 FRONT HOUSING
GARRETT –31 ACTUATOR
GROUP A CAM BELT
GROUP A COIL
GENUINE RS500 INTERCOOLER WITH MODIFIED T34 FITTINGS
PACE RS500 FAST ROAD RADIATOR (50mm core)
PRO-ALLOY SLIMLINE UPRATED COOLING FANS
PACE TURBO COOLER
BAILEY MOTORSPORT TURBO OIL FEED & PRE FILTER
SPEC-R GROUP A BREATHER/SEPARATOR SYSTEM
SPEC-R CAMBELT COVER
SPEC-R SWIRL POT
SPEC-R WATER COOLED POWER STEERING TANK
SPEC-R HEADER TANK (with sight glass)
SPEC-R WASHER BOTTLE
STANT 21-25psi RADIATOR CAP WITH LEVER RELEASE
SAMCO BOOST & WATER HOSES
BRAIDED FUEL HOSE -6 WITH EARLS FITTINGS AND CLAMPS
(from filter to fuel rail, and regultor to tank)
MIKALOR STAINLESS STEEL HOSE CLAMPS THROUGHOUT
2 AIR SCOOPES ABOVE INTERCOOLER WITH DUCTING TO AIR FILTER
MONGOOSE 3in STAINLESS STEEL EXHAUST (with Powerflex hangers)
K&N GROUP A CONE FILTER
WEBBER MARELLI LEVEL 8 ECU WITH PECTEL BABY BOARD
PECTEL 12 POSITION BOOST CONTROL (in car)
4 X 403 GREY INJECTORS (503cc)
WRC AIR INJECTORS WITH –4 BRAIDED HOSE AND EARLS FITTINGS
WATER INJECTION
044 FUEL PUMP
3 BAR MAP SENSOR
MOTORCRAFT AGP 701 SPARK PLUGS
FORD MOTORSPORT IGNITION LEADS
MILLERS 10w60 FULLY SYNTHETIC OIL
9 OIL COOLER FOR POWER STEERING
TRANSMISSION
STANDARD BORG WARNER T5 WITH QUICKSHIFT
CASTROL AUTOMATIC TRANSMISSION FLUID (as standard)
LIGHTENED & BALANCED FLY WHEEL
ALCON 6 PADDLE, STANDARD FORD COVER
RECONDITIONED PROPSHAFT WITH UPRATED UJ’S
QUAIFE ATB 7 ½ INCH DIFF, 3.64:1 FINAL DRIVE (standard)
CASTROL EP80W-90 OIL
POWER
405 bhp @ 6030 rpm
397 lbft TORQUE @ 4020 rpm
REV LIMITER : 7100 rpm
PEAKS @ 32 psi, HOLDS 28psi
BUILT & TUNED BY HARVEY GIBBS
SCS, PETERBOROUGH. 01733 576614
MAPPED BY AHMED BAYJOO ON DYNO & IN CAR
BRAKES
FRONT: AP RACING CP5555 6 POT CALIPERS
330mm x 28mm DISCS & BELLS
FERRADO DS2500 PADS
REAR: 4x4 CALIPERS
300mm x 22mm DISCS & BELLS
FERRADO PADS
GOODRIDGE BRAIDED HOSES ALL ROUND
CASTROL SRF DOT 4 BRAKE FLUID
SUSPENSION
FRONT: GAZ COILOVERS
10 INCH SPRINGS, 325 LB
POLY BUSHED ANTI ROLL BAR AND TRACK CONTROL ARMS (inner
& outer)
SPEC-R TWIN BAR STRUT BRACE (chromed)
REAR: GAZ COILOVERS
12 INCH SPRINGS, 225LB
GROUP N REAR BEAM BUSHES (donuts)
STANDARD FORD TRAILING ARM BUSHES
POLY BUSHED REAR ANTI ROLL BAR
REAR SHIM KIT
SPEC-R REAR STRUT BRACE
INTERIOR
STANDARD RECARO INTERIOR
RS MOTORSPORT 3 SPOKE STEERING WHEEL
WILLINS 4 POINT HARNESSES
ELLIOT 8000 RPM REV COUNTER
DEFI OIL PRESSURE & TEMPERATURE AND EXHAUST GAS TEMPERATURE
DEFI CONTROLLER (with record and playback)
APEXI 2.5 BAR BOOST GUAGE (with record and playback)
S.E.C.S MONITER
PECTAL 12 POSITION BOOST CONTROL
SPEC-R WATER INJECTION TANK IN BOOT
FIRE EXTINGUISHER
EXTERIOR
FRONT WHEELS : COMPOMOTIVE MO, 7 I/2in x 17in ET 37
GOODYEAR EAGLE F1’s 215/40
REAR WHEELS : COMPOMOTIVE MO, 8in x 17in ET 35
ALL PAINTED IN ANTHRACITE WITH DIAMOND CUT & POLISHED RIM
GENUINE RS500 FRONT SPLITTER
GENUINE RS500 FOGLIGHT GRILLES, WITH AIR DUCTING TO AIR FILTER
SPEC-R REAR BUMPER/EXHAUST HEAT SHIELD
405 BHP DECAL ON WINGS
07974 459192
Old Feb 3, 2006 | 10:50 AM
Ian3dr's Avatar
Ian3dr
Further pics can be seen here of the restoration..........
https://passionford.com/forum/viewto...er=asc&start=0
And here at the shows........
http://www.rscarshows.co.uk/
Just search for Ian3dr.
Old Feb 3, 2006 | 10:52 AM
RS220Turbo's Avatar
RS220Turbo
Best of luck with the sale mate, Lov the car
Sunny
Old Feb 3, 2006 | 11:00 AM
richj's Avatar
richj
I'm off out to buy a euro millions lotto ticket, win that tonight 180million in the bank tomorrow and then straight over to buy this car on monday. Stunning car shame to sell it.
Old Feb 3, 2006 | 11:01 AM
domink_goodfellow's Avatar
domink_goodfellow
Im lost for words, absolutly breath taking. I love it!!!!
Old Feb 3, 2006 | 11:10 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I'd like to buy it, do rally-cross in it for a season, and then stick it back on the bufty stand .
However, I haven't got £20k to waste on such frivolities .
Old Feb 3, 2006 | 11:28 AM
Someone better buy it soon, it was 18K 10 minutes ago
Nice car if you prefer cleaning to driving though
Old Feb 3, 2006 | 11:34 AM
rscossiechris's Avatar
rscossiechris
THE VERY BEST OF LUCK TO U WITH THE SALE IAN ITS A STUNNING CAR AND I'M ALSO OFF TO BUY A EURO MILLIONS TICKET
Old Feb 3, 2006 | 11:53 AM
gingeRS's Avatar
gingeRS
I Love this car
even if i had 20k to spend on a car i wouldnt buy it as i would be afraid of using it
have seen it at nat day, ford fair etc and it is totally flawless
much better than uncle henry decided to make it
Old Feb 3, 2006 | 12:31 PM
rapidcossie's Avatar
rapidcossie
the car is amazing mate! but 50k ouch!
Old Feb 3, 2006 | 12:42 PM
Harris.'s Avatar
Harris.
Well worth the money !! Good luck with the sale m8
Old Feb 3, 2006 | 01:00 PM
The DIVA's Avatar
The DIVA
Stunning car matey....
Good luck with the sale..........What you planning next then..
Old Feb 3, 2006 | 01:08 PM
M7 COS's Avatar
M7 COS
WOW!!!
I can't believe this car is for sale!
One of my favourite 3 DRs ever.
A concours winner for around £20K is a bargain in my opinion.
Does this now mean that 1st, 2nd and 3rd at National Day Modified Cosworth Concours have all been sold or are for sale?
I know Arty sold his and Scott was thinking of selling his, but did he sell it in the end?
Old Feb 3, 2006 | 01:59 PM
gazcos's Avatar
gazcos
Ian ,No No No not now. One of my personal goals was to get my shop open and then try and persuade you to sell me your car but its no due to open for another 6 weeks or so i,ll have to set myself another target now LOL
Without wishing to state the obvious,those of you that have got the money now call Ian because this car is a bloody Masterpeice
Old Feb 3, 2006 | 02:43 PM
ryan_belfast's Avatar
ryan_belfast
Trying to talk the old man into selling his 3 door (tiffs old one - Scrapper) and buy this one...
Old Feb 3, 2006 | 03:01 PM
3drbadboy's Avatar
3drbadboy
i know this car inside out and i can tell you that you will not find one any better condition than this ! i wil be very sorry to see it go too!
ian ya dead
Old Feb 3, 2006 | 04:06 PM
bigpower's Avatar
bigpower
Good luck with the sale bud!
Old Feb 3, 2006 | 04:08 PM
Staffi's Avatar
Staffi
What are you getting next Ian?
Old Feb 3, 2006 | 04:49 PM
kevin's Avatar
kevin
truly superb 3dr as the carlesberg ad says
probably the best 3dr in the world.
i saw this car when ian bought it as a nice standard example
and watched it evilve into what it is today
a very much admired and very well presented car
good luck with the sale mate, will you take px
.....transit fridge van ???
ha ha kev
Old Feb 3, 2006 | 04:55 PM
fireandskill1's Avatar
fireandskill1
Big Big decision Ian Mate but I know it is a decision you have been toiling over for a while now. All the best with the sale and all the best for the future........
Old Feb 3, 2006 | 05:01 PM
Spiky's Avatar
Spiky
best of luck with sale,
but 20k???? isn't that a bit under priced
Old Feb 3, 2006 | 05:02 PM
Dunccoss's Avatar
Dunccoss
well ian what can i say
Best off luck with the sale mate and i hope you dont regret selling it
Old Feb 3, 2006 | 05:14 PM
RobS's Avatar
RobS
Good luck mate, worth every penny of 20k and if could sell mine id be up 2mrw to but it. i just hope it goes to a good home.
at least it aint getting broke
RST's Avatar
RST
Old Feb 3, 2006 | 05:18 PM
rsnutters1's Avatar
rsnutters1
as Tina would say - simply the best
Old Feb 3, 2006 | 05:29 PM
jay man's Avatar
jay man
that is one amazing car and i am not a lover of 3dr's, saw this in harvey's and it unreal. mike you'd kill yourself doing rallycross you're a straight line merchant
Old Feb 3, 2006 | 05:40 PM
G2 FSR's Avatar
G2 FSR
The best 3dr on the planet!
Old Feb 3, 2006 | 05:44 PM
M.A.D.RST's Avatar
M.A.D.RST
That is stunning Good luck with the sale
Old Feb 3, 2006 | 06:16 PM
Csm's Avatar
Csm
Fukin beutiful buddy Just shot in ma pants
Wish i had the money
Old Feb 3, 2006 | 06:22 PM
kurdt5's Avatar
kurdt5
that is just the nuts.......stunning.
Old Feb 3, 2006 | 06:38 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
As all above, trully stunning mate, it should be kept in a show room, far to good too use
Old Feb 3, 2006 | 06:39 PM
T4KAF's Avatar
T4KAF
i have seen this at few shows and its on "the story of ford sierra dvd" and its awesome m8,got e a few pics on ma pc of it,it is ma fav 3dr sierra cossie!!
Old Feb 3, 2006 | 06:51 PM
Dunccoss's Avatar
Dunccoss
ian sell it to spadge he allways said he whould buy it and then brake it and sell all the bits on ebay
Old Feb 3, 2006 | 07:12 PM
jacko's Avatar
jacko
can body parts be sold on ebay
Old Feb 3, 2006 | 07:29 PM
SteveB's Avatar
SteveB
Old Feb 3, 2006 | 08:29 PM
Staffi's Avatar
Staffi
DONT BRAKE IT FOR FOOKS SAKE
Old Feb 3, 2006 | 08:38 PM
Rab's Avatar
Rab
Fucking superstar........
Thats making me physically sick...................
............ with envy
20k is a bargain. I'm just off to South America to sell some of my less useful organs
Old Feb 3, 2006 | 09:00 PM
Lee Reynolds's Avatar
Lee Reynolds
Ian,
I NEVER thought i would ever see this
Old Feb 3, 2006 | 09:19 PM
macker's Avatar
macker
STUNNING M8, Wish i had 20k...Best of luck with the sale....Top motor
Old Feb 3, 2006 | 10:18 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Im not going to buy, and never could unless my numbers come in!
Stunning, Hope you a god sale Ian
