any VW tech's on here?
Old Feb 3, 2006 | 09:05 AM
swerv's Avatar
swerv
Default any VW tech's on here?
need some help with a passat V5 if there are any people with knowledge on VW's please PM me or post here
Old Feb 3, 2006 | 01:04 PM
AlexF's Avatar
AlexF
What do you want to know?
alex
Old Feb 3, 2006 | 01:59 PM
swerv's Avatar
swerv
basically car has a fault and want to know if its a common or known fault and if there is a standard fix for it.
when driving in cold conditions, outside temp, with your foot at a constant pressure on the accelerator it feels like it is hunting/pulling back and forth, a bit like putting your foot on and off!!
the colder it is the worse it is
Old Feb 3, 2006 | 02:32 PM
AlexF's Avatar
AlexF
and what year is the car?
I work with a couple of vw ex-techs
Alex
Old Feb 3, 2006 | 02:36 PM
swerv's Avatar
swerv
its a 2002 52' plate
Old Feb 3, 2006 | 03:14 PM
Jonzy's Avatar
Jonzy
Tell him to find someone with vagcom and get them todo a fault code check. Will tell you exactly whats wrong.
Saves a lot of headaches in the long run trying to guess which sensor has had a fit.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
