loosing boost!!
Old Feb 2, 2006 | 10:41 PM
lammylama's Avatar
lammylama
Default loosing boost!!
recently put a new actuator on my 2wd saff coz the old one was shagged but its not holding boost very well.The car was set up to hold22/23psi but at the moment its peaking at 24 and holding about 17,so its way down on boost.Why is it not holding boost......to get it to hold22 psi i have to set it to peak at about 28psi which is too high.So ive backed it off til i get it sorted.Could the amal valve be knackered or something else.Ive checked all hoses and there are no leaks at all.
Old Feb 2, 2006 | 11:01 PM
cossie604's Avatar
cossie604
Have you checked that your pipes are on the right way round on the amal valve?? The valve has letters on each pipe to help
Stu.
Old Feb 3, 2006 | 08:14 AM
JamesH's Avatar
JamesH
It could be SO many things mate.
I had this problem, it turned out to be a leak to my boost gauge.
I will pull up an email reply I got from Karl Norris when I had this problem
Old Feb 3, 2006 | 08:25 AM
JamesH's Avatar
JamesH
Here's what my problem was:
https://passionford.com/forum/viewtopic.php?p=2042048
Karl's reply:
Hi Charlie,
It will almost certainly be an air leak under boost.
Things to check:
Dump valve (if fitted) check diaphragm isn't split and that it seals
correctly.
All boost hoses are in perfect order with no splits or tears and that the
jubilees are tight
Inlet manifold gasket to head
Plenum cover gasket to head
Throttle body to inlet manifold gasket
Injector o rings to inlet manifold
Any of the small bore pipes coming off the plenum cover or even a leak going
to your boost gauge!!
I'll put money on it that its one of the above!!!
Let me know,
Cheers,
Karl
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
