FAO PEEPS RUNNING ALS
do you run your turbo water cooled or not???
i know alot of people in rst's dissconnect the water feed on standard cars as some belive its better but never noticed on als equipped cars??
(i have the proper 247 shaft in the turbo)
opinions please
cheers
marc
opinions please
cheers
marc
M K
i brought gus s maram shafted turbo and i was thinkin this aswell but im running a pro alloy turbo cooler so this should compensate for the extra heat!
i hope
i hope
mmmmm
will have to speak to tommy about that then as my housing is quick release too???? so wanna keep it realy or ive seen em sell fo Ł150 on there own
spose thats what the als is for
M K
yeah! but id rather it have quick spool up and use the als for fun as apposed use the als all the time!
it also depends how its mapped! my mate has a 63 on his cossy managed 1600 rs turbo and it was fookin laggy but the bloke who mapped it put a bit of ignition advance low down in the rev range and this proper transformed the way it drives now!
so you might be ok!
so you might be ok!
big_wig_074
dont know off hand mate
check the end of the shaft to see if it has 247 stamped on it
also put a magnet on the shaft if it isnt magnetic it prob is
Eigdoog
Sep 13, 2015 05:46 AM
