full list of hoses needed for efi set up please,,,
my new engine spec is 1600cvh efi/t34 ect
ive never used efi before so unsure on some of the hoses il need?
MY TOP BOOST HOSE FROM COOLER TO INLET IS CUSTOM SO I WONT NEED THIS.
IM USING A T34 SO WILL A ERST BOTTOM BOOST HOSE BE OK?
i know i will need the following-
RAD-THERMOSTAT-TURBO WATER FEED,,,,,normal efi
HEADER TANK-WATER PUMP-RAD,,,,normal efi
THERMOSTAT-HEATER MATRIX,,,normal efi
but what others are needed??? where does the other heater matrix pipe go to?
gonna use an air/oil cooler so wont run the water through standard ford cooler
cheers
marc
cheers
marc
marky_g
Aug 15, 2015 10:43 AM
