power engineering system 2 engine components?
Old Feb 2, 2006 | 10:21 AM
ivorbiggun's Avatar
ivorbiggun
Default power engineering system 2 engine components?
Hi guy's, I've bought a Power engineering system 2 1.9 cvh, which is knackered. Have any of you got any idea what car the rods and pistons
were originally from. I phoned PE up and it's a big secret apparently...
Old Feb 2, 2006 | 12:09 PM
©hatter Box's Avatar
©hatter Box
merc cosworth pisons and rods iirc
Old Feb 2, 2006 | 12:35 PM
Badman38's Avatar
Badman38
yes as alex said merc teflon coated pistons. tr7 rods and 1.8 sierra crank
i use to run one of these but i split a liner
Old Feb 2, 2006 | 06:24 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
i hear its not a straight bung in job tho they all have to have machining done
Old Feb 2, 2006 | 08:08 PM
ivorbiggun's Avatar
ivorbiggun
Cheers lads
Did you mean 'Kompressor' pistons Alex?
The Merc Cosworth had bores of 95.5
whereas my pistons are a Knats chuff under 83mm.
I've completed the dismantle now and the fun
really starts.......
As for 'machining' XRon40's, the rods I've got have had a file taken
to them to remove the tell tale manufacturers markings
(it's a secret remember) and presumably to allow the crank
to rotate some material has been removed from the rods around the bigend. And, (for goodness sake I'm reminded of a particular tea commercial
from way back/pass the monkey wrench) half the tops of the rod studs have also
been milled....I can't wait to see the difference in weight of each rod as I
can only imagine the lump must have been very poorly balanced judging
by the ovalised bores and broken pistons skirts/still at least the rod bolts
held (amazingly)for the massive 28,000 miles the engine has completed......
Whoever built this should be dragged out to the car park and kicked
repeatedly till the police arrive/still it could be worse guys 'someone'
might still be selling these and one of you could still shell out for one...
I'm off for a lie down whilst I contemplate the sheer engineering genius of cast pistons in a turbo charged motor!
Old Feb 2, 2006 | 08:37 PM
1.9 xr2 on 40's
st170 breaking
my PE+ 1.9 cost me nowt and has done 5k so ill persevere
not that its turned more than 1 mile in the last 4 years
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Old ford
Jul 31, 2015 06:50 AM
