missing under boost?
Old Feb 1, 2006 | 09:07 AM
gingeRS's Avatar
gingeRS
Default missing under boost?
my car was being a pain to start so i removed the plugs and gave em a damn good clean
car now starts much happier but is misfiring under boost now?
has been sat for 2 weeks or so unused, would the fact that the plugs were covered in crap affect the fuelling as it was set up at scc shortly before i cleaned them
may pop up there later, just checking i havent missed something
Old Feb 1, 2006 | 09:59 AM
gingeRS's Avatar
gingeRS
anyone?
Old Feb 1, 2006 | 10:06 AM
big_wig_074's Avatar
big_wig_074
maybe ur leads are fooked,or maybe u need better plugs,or your dizzy,or dizzy cap,check the whole system mate as its often difficult to diagnose
Old Feb 1, 2006 | 10:13 AM
Fiecos Dan's Avatar
Fiecos Dan
plug gaps usually or worn/faulty.
clean them/ or replace then try 0.5mm gap.
or coil/leads etc etc
Fiecos Dan's Avatar
Fiecos Dan
double post
Old Feb 1, 2006 | 10:16 AM
gingeRS's Avatar
gingeRS
will check all
plugs are standard gap (0.8mm) bar of boost
will check leads and connections etc
typical, just as i'm trying to sell it too
Old Feb 1, 2006 | 11:25 AM
XRT_si's Avatar
XRT_si
My car had same thing but its was a melted plug if that helps at all
Old Feb 1, 2006 | 11:28 AM
Fiecos Dan's Avatar
Fiecos Dan
Yeah, i always run my car with tools and spare plugs, but i haven't had a melted plug for 3+ years, normally down to det/fuelin or a faulty plug
Old Feb 1, 2006 | 11:31 AM
Originally Posted by gingeRS
will check all
I would try closing them up to .5 or .6mm TBH
Old Feb 1, 2006 | 01:38 PM
gingeRS's Avatar
gingeRS
seems to have cured itself now
it was sitting for a fortnight, and gave it a good run, washed it will have some new photos soon.
timsrs
Nov 13, 2018 11:48 AM
gambo08
Feb 4, 2016 10:49 PM
Mark RS
Oct 12, 2015 06:01 AM
Fil
Sep 30, 2015 12:08 PM
Russ Payne
Sep 25, 2015 08:29 PM
