Oil seeping
Old Jan 31, 2006 | 11:34 AM
auralisRS's Avatar
auralisRS
Default Oil seeping
After just doing a head gasket, there is a slight weep of oil from the front right of the head gasket, where the oil galley is, and its running down to where dizzy, what a bummer.....
Now I will have to do it again...or maybe I will put some radweld in my oil
Does anyone recommend using HYlomal or something around these galleries on the gasket...
Old Jan 31, 2006 | 01:55 PM
Dave Henshall's Avatar
Dave Henshall
thats why teh head and block have to be 100% flat - otherwise siad leaks occur
i know as im guilty also
Old Jan 31, 2006 | 02:19 PM
MONSTER's Avatar
MONSTER
Default Re: Oil seeping
Originally Posted by auralisRS
I will put some radweld in my oil...
As far as i'm aware you should never use jointing compound/gasket sealer on a head gasket..
Did you have the head checked whilst it was off?
Old Jan 31, 2006 | 02:49 PM
auralisRS's Avatar
auralisRS
Yep, head was skimmed, someone said that the gasket sometimes have a raised reinforced area around the galleries....
Old Jan 31, 2006 | 03:43 PM
rizla's Avatar
rizla
where did you get the gasket from ?
Old Jan 31, 2006 | 04:19 PM
Chris Honeywell's Avatar
Chris Honeywell
M8 mine also leaks from said area
i just live with it atm
Old Feb 1, 2006 | 11:25 AM
auralisRS's Avatar
auralisRS
Gasket came from one of the reputable dealers that was recommended on here, forget the name, at work at mo, so can't dig receipt out.....
Old Feb 1, 2006 | 03:01 PM
rizla's Avatar
rizla
Dont matter mate just wondered
I get all my bits from Woodford Motorsport
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
