Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
heater problem -anyone got any ideas please?
Old Jan 30, 2006 | 09:33 PM
MATCOS's Avatar
MATCOS
Default heater problem -anyone got any ideas please?
My other halfs 1999 Puma has a problem, well technically it's 2 problems but they may be related
When you squirt the windscreen washers it sounds like they are empty and only a little bit of water comes out (it is full and it is not frozen!)
The second part is the heaters/aircon, when you drive under 40mph ish the heater and aircon work fine but when driving for a while or if you speed above 40mph the temperature is constantly hot and not cold
Has anyone had a similair problem or have any suggestions please.
Many thanks
Old Jan 30, 2006 | 10:29 PM
scott-cos's Avatar
scott-cos
sounds like the filter on the pump is blocked. you need to remove the washer pump and the filter. clean it out and re-fit and try it.
not to sure about your other problem though.
scott
Old Jan 30, 2006 | 11:23 PM
steve211's Avatar
steve211
could be your heater valve causing probs with temps......know problem on pumas and fiestas and had mine replaced for similar problems when i had mine
Old Jan 31, 2006 | 05:29 PM
MATCOS's Avatar
MATCOS
Cheers lads
Old Feb 25, 2006 | 02:51 PM
big-dirty-dog's Avatar
big-dirty-dog
my escos had the same problem with the washer jets pulled the hose off the pump,tested,shot out water thick and fast washer jets were unblocked,had a blockage in the supply pipe to the jets blew out blockage with airline,probley the same
Old Feb 25, 2006 | 03:11 PM
MATCOS's Avatar
MATCOS
Rsmat
63
Sep 25, 2015 12:11 PM
RSBryden
Sep 6, 2015 08:39 PM
ST-170
Sep 4, 2015 11:02 AM
Ben26
Sep 3, 2015 07:55 PM
