FAO Safechav
Old Jan 30, 2006 | 05:43 PM
kevsrs's Avatar
kevsrs
Default FAO Safechav
Following our lengthy discussion here https://passionford.com/forum/viewtopic.php?t=164677 i bought a used distributor off a guy on RSOC and fitted it today and problem solved
I lined the new dizzy up with the line on the block and it started straight away and runs fine
So thanks for your help mate as i wouldn't have fixed it otherwise
Old Jan 31, 2006 | 02:24 AM
SafeChav's Avatar
SafeChav
YEAAAAAA!!!!
Thats what i like to hear, someone else said thanks earlier aswell
Thats what we are all here for
Just one last thing though, either check the timing yourself with a gun or get someone else to check it, in theory it should be spot on but check it just incase its slightly off.
I bet you were chuffed that you changed it yourself. Now would be an IDEAL time to learn how to use a timing gun, if the timing is out you can't cause any damage with it ticking over, only when your giving it some stick will damage be caused.
Old Feb 1, 2006 | 07:28 PM
kevsrs's Avatar
kevsrs
I think i will need to get the timing done cos the revs have started to jump up and down between about 800 - 1100 rpm when idling
Does that sound like timing problem to you?
Old Feb 1, 2006 | 07:36 PM
SafeChav's Avatar
SafeChav
Could well be if the timing is out, i'd get it checked, if its wrong u could worst case scenario melt a piston or something
Old Feb 1, 2006 | 07:57 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
and heres me thinking safey was just another wanker like me,
Old Feb 1, 2006 | 07:59 PM
SafeChav's Avatar
SafeChav
I could never be as big a wanker as u
Old Feb 1, 2006 | 08:11 PM
akito-man's Avatar
akito-man
unchballs:
base190380
May 2, 2007 10:55 AM
Chris S
Jan 4, 2007 07:11 PM
Disabled Account
14
Oct 25, 2005 06:55 AM
Disabled Account
Jun 14, 2005 06:17 PM
