Low compression do I need it
Old Jan 30, 2006 | 11:47 AM
davidnormanuk's Avatar
davidnormanuk
Default Low compression do I need it
I am building an engine at the minute and am debating wether or not to go low compression. I am only wanting to run about 15psi of boost and would like the car pull more at the bottom end rather than the top. Should I leave it standard with regards to the compression ratio. It will be running a stage 2 turbo as thats what I've got and just had it rebuilt but want as little lag as possible. I have been looking around and it seems the higher the compression the more torque you get but obviously I can't go too far due to detonation etc.
Old Jan 30, 2006 | 12:39 PM
Badman38's Avatar
Badman38
Default Re: Low compression do I need it
all depends on what power you eventually want to run if your goner be happy with 15psi then leave the compression ratio aloan.
Old Jan 30, 2006 | 02:51 PM
turbo.jon's Avatar
turbo.jon
Running 15psi i would keep it std comp
Old Jan 30, 2006 | 03:14 PM
zippyobrien's Avatar
zippyobrien
low compression will be shit at the bottom end.
evos run around 9:1 and lots of boost as standard
and im running 20psi on standard bottom end
Old Jan 30, 2006 | 04:18 PM
addiction's Avatar
addiction
mine is low comp and i only run 14psi. i got 236lbs/ft torque which equals loads of bottom end grunt
Old Jan 31, 2006 | 11:16 AM
davidnormanuk
Thanks for the replies guys. Gonna keep it standard comp.
Old Jan 31, 2006 | 12:25 PM
dave_y's Avatar
dave_y
whats the most boost you can run on a standard setup. i was told that it was 18psi
Old Jan 31, 2006 | 02:44 PM
JesseT's Avatar
JesseT
~22psi without any trouble and upto ~29psi with careful setup.
Old Jan 31, 2006 | 03:24 PM
davidnormanuk
I bet at 29psi it would pull your arms off. I couldn't imagine running an RS at that sort of boost.
Old Jan 31, 2006 | 04:28 PM
dave_y's Avatar
dave_y
fookin hell.
my mate had an RS Turbo and he was trying to blow up his 1.6CVH as an excuse to upgrade to ZVH power and he ran it at 27psi for 2 weeks before it died. That was without adjusting the fuelling too!
i would imagine that after 18psi your gonna need a fith injector of some sort?
Old Jan 31, 2006 | 06:18 PM
addiction's Avatar
addiction
but how long will it last before it kinda cries for help?
Old Jan 31, 2006 | 06:34 PM
dave_y's Avatar
dave_y
i think its performance Ford that have an RST running stupidly high boost on standard engine and thats seems to be lasting
Old Jan 31, 2006 | 06:38 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
1bar? Evo's don't have a CVH either so it's a bit pointless comparing the engines.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Tank Mike
Sep 26, 2015 08:07 AM
