xr2i and frst cam?
Jan 29, 2006 | 02:58 PM
xr2i and frst cam?
as these are the seame head do they have different profile cams as one is a turbo?
Jan 29, 2006 | 04:06 PM
The heads are the same but I'm unsure on the camshaft
Jan 29, 2006 | 09:04 PM
I don't think ford will thell you... All that I know is that ERST used the camshafts of XR2/XR3/XR3i MFI
If Ford used the same pistons on ERST and FRST head height should be a little bit lower than on standard XR2i's
Jan 29, 2006 | 09:59 PM
anyone put a xr2i head straight on?
Jan 30, 2006 | 10:21 AM
according to microcat 2i and turbo cam is the same finis code 6179242 hope this helps mate
Jan 30, 2006 | 11:01 AM
Quote:
that's just what I expected
Jan 30, 2006 | 04:45 PM
Jan 30, 2006 | 05:48 PM
The XR2i and FRST cams are EXACTLY the same, as are the Escort XR3i and RS Turbo cams, its common to use the FRST cam in an ERST aswell because the later cams produce more power than the earlier version.
Jan 30, 2006 | 09:46 PM
good good means i aint gota change it lol
Jan 31, 2006 | 02:06 AM
Fitting a brand new cam usually see's power gains aswell, because a CVH cam wears stedaily from the moment it is fitted (poor top ends)
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
