Drilling holes in my garage
I'm looking to panel the inside of my garage but i cant get any drill to touch the walls
think they must be reinforced with steel.Tried drilling thourgh the concrete then after about 3mm it stops,tried masonary drills,hss drills etc.Any ideas ???
Cheers Russ
think they must be reinforced with steel.Tried drilling thourgh the concrete then after about 3mm it stops,tried masonary drills,hss drills etc.Any ideas ???Cheers Russ
get a better drill mate,,,,,,,,, just means yours aint up to the job,,,,,, drill it too much and you may burn out the clutch too
i sugest you hire one and burn that one out instead
if uve got a few to drill mate go to hss and hire an sds drill, they should be able to sort you out with drill bits as well, if your fitting battens to the wall you could use a plaslode gas nailer (alot more fun), hilti do one that uses small charge caps but i think you need a license to hire one (not sure bout that)
I was thinking of using 18mm marine ply so i can put up some shelves and cabinets etc.Was just going to panel around the area where my bench and toolbox is.
Its a compton garage thats made out of those bolt together panels,strong as fook
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
