diff oil
Old Jan 28, 2006 | 11:48 PM
Twellsie's Avatar
Twellsie
Default diff oil
i have had my saff 4x4 for about 6 months now, is there any way of checking my diff oil, do i need to be checking my diff oil, if so how often should i check it??
Old Jan 29, 2006 | 12:02 PM
higgsey's Avatar
higgsey
hi mate
i would check both diffs and the gearbox and transfer box because when things go they will be expensive.
Old Feb 2, 2006 | 04:34 PM
Twellsie's Avatar
Twellsie
and how do you check it?
Old Feb 3, 2006 | 07:58 AM
higgsey's Avatar
higgsey
if you look in the workshop manual it shows you. i would change all the oils unless they were changed already ??
i down loaded the manuals from a link on passion ford but i think you need to be a gold member first.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
